Re: Ih sickle bar mower
Posted by SadFarmall on June 11, 2011 at 04:58:00 from (138.217.75.187):
In Reply to: Ih sickle bar mower posted by restorust76 on June 05, 2011 at 13:41:18:
They are a good mower. I still use a GL-25-VO with 7ft cut behind a Farmall M. It goes out alongside the big disk mower every year. As to the hydraulic cylinder there are at least arrangements for lifting the cutter bar. Either a long rod, which hits you on the elbow, a one way hydraulic cylinder mounted under the tractor and connected via the pulley to lift the cutter bar or a two way cylinder on the mower frame which lifts and lowers the cutter bar. The last arrangement is by far the best for working, but it does have a tendency to break gag levers if not set correctly. Two pictures: one of a 25V behind a Farmall H and the other showing the frame of the mower. third party image third party image
