Re: potential 650
Posted by Rick(MN) on June 11, 2011 at 10:02:30 from (184.100.67.198):
In Reply to: potential 650 posted by red bearing on June 11, 2011 at 05:12:11:
First you need to establish if fuel is making it to the cylinders. If, when running on gas, you get white smoke upon advancing the throttle, you know the injectors are spraying fuel into the cylinders. At that point, I would start suspecting a compression on the diesel side problem....starting valves perhaps not closing. Listen closely to what the seller says about his trying to diagnose the problem.
