Re: Farmall M clutch replacement
Posted by SadFarmall on June 11, 2011 at 16:10:14 from (124.176.226.66):
In Reply to: Farmall M clutch replacement posted by Peter Hendrickson on June 11, 2011 at 16:00:59:
According to the Servicemans Guide:
Clutch is removable through an opening in bottom of clutch housing. The procedure is as follows:
1). Remove four bolts from the clutch joint. (Marked 1 in picture)
2). Remove clutch release sleeve carrier. (Marked 2 in picture)
3). Remove clutch shaft together with thrust bearing.
4). Remove three cap screws holding clutch to flywheel and after placing washers under the head of cap screws replace transpose them to the three holes provided for compressing the clutch spring.
5). Remove the remaining cap screws and lift out clutch.
6). Reassembly is made in the reverse procedure, but be sure to install clutch shaft before releasing pressure on clutch springs and be sure to assemble clutch joint ring with convex side toward clutch.
Good Luck! SadFarmall third party image
This post was edited by SadFarmall at 16:11:30 06/11/11.
