Posted by equeen on June 11, 2011 at 16:15:24 from (209.102.248.55):
In Reply to: Re: Cub IS Charging? posted by Ludwig on June 11, 2011 at 14:44:40:
I understand your points; but I'm not getting that voltage.
The battery is less than 6 months old and was temporarily taken from a well-running tractor. It charges fine with a regular battery charger.
I expected the battery to be somewhat drained after two starts and the trip - but had more volts than when I started. So, it was getting juice - maybe just enough of a trickle to do the job.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
