Re: Farmall M clutch replacement
Posted by Haas on June 11, 2011 at 16:39:00 from (75.201.73.255):
In Reply to: Farmall M clutch replacement posted by Peter Hendrickson on June 11, 2011 at 16:00:59:
Sad Farmall gives you good instructions. However, I found it next to impossible to get the clutch shaft out and back in without removing the clutch release fork and the cross shaft that it is mounted on. The cross shaft is removed by removing the clamp bolts in the release fork that secure it to the cross shaft. There are two heavy washers that serve to key the fork to the shaft. When the bolts and washers are out, you can slide the shaft out the side of the clutch housing. That is after you disconnect it from the pedal linkage.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
