Re: Super A rear wheel weights
Posted by pheel on June 12, 2011 at 03:28:35 from (75.207.185.98):
In Reply to: Super A rear wheel weights posted by Cris on June 11, 2011 at 20:31:58:
i just last week had the same problum, 1st i had the a blocked up or so i thought, the weight will shift when you remove the weight on the right side (from setting in the seat). i had 2 bolts that were rusted in i cut the nuts off using a chisel, didn't help. i finally got it off because the bolts were so rusted they broke, when it fell that is when the weight shifted could have been seriously hurt, after it was off i beat on it used pb blaster for a hour or so, didn't help either so i will be using a tourch to burn them out
