Re: 300 rear main seal
Posted by CNKS on June 12, 2011 at 06:56:21 from (216.144.104.128):
In Reply to: Re: 300 rear main seal posted by chrism in tn on June 11, 2011 at 19:32:00:
You don't have to do anything to the crank except replace the seal, you don't have to remove the rear main if that's what you mean. The pan has to come off because it bolts to the lower half of the seal housing. If you remove the flywheel it should be self-explanatory. You really need a splitting stand, particularly if it has a single or narrow front. BUT, on my Super H I removed the pan first, and placed a square bar under the block, supported by a jack stand on each side.
This post was edited by CNKS at 07:06:55 06/12/11.
