Posted by Shawn in PA on June 12, 2011 at 14:11:34 from (24.154.38.87):
SM got a pretty steady miss on #1 cylinder. Just did the head gasket about a month ago, and changed out the plugs, wires, cap, rotor, points ect. So I proceeded to check the manifold studs, and all were tight. Passed the propane test. I suspected a stuck valve, but after a compression check, it turns out that wasn't the case. All the valves were set to tolerance and still tight. No bent rods. Timing wasn't off either. Turns out, the new Autolite spark plug in the number 1 hole had failed... Swapped in a D-21 from my H and it purred as it should. Moral of the story, start with the simple stuff first, and don't assume new parts don't fail right out of the box...lesson learned. Shawn
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
