Re: tractor swap.
Posted by Raw in on June 12, 2011 at 14:22:45 from (173.24.197.153):
In Reply to: Re: tractor swap. posted by Allan In NE on June 12, 2011 at 12:38:07:
If you are talking about a 4 section peg tooth drag, it should play with it in 4th gear. W used to pull a 4 section (20ft) drag with a C in third except in the sand and it would pull hard there.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
