Re: Mounting rear rim to hub, Something's not quite right...
Posted by Roger46 on June 12, 2011 at 18:47:59 from (75.245.62.225):
In Reply to: Mounting rear rim to hub, Something's not quite right... posted by Crazy Red Power in SE-WI on June 12, 2011 at 16:09:23:
What I have done is to jack up wheel so it is off the ground and loosen all the nuts. Then just finger tighten them and check the gap between the rim and the cast center. Use a piece of shim or something and adjust the rim so the gap is constant around the whole wheel. May have to tap with sledge hammer or wedge from the ground. After the gap is close to the same then start tightening alternately across the wheel like when torquing lug nuts. Make sure the gap stays constant. This will also make for a smoother ride down the road; because, if the wheel is off center there will be a once-around bounce you will notice most in road gear. Roger
