Re: Farmall 460D Power Steering
Posted by pete 23 on June 12, 2011 at 19:09:37 from (74.32.230.16):
In Reply to: Farmall 460D Power Steering posted by John Athey on June 12, 2011 at 17:43:57:
If the lines were crossed it would do same thing in both directions as it would be fighting you hyd against manual steering. If it turned ok running both directions with wheels off the ground that tells you that you are not getting enough power assist in the direction it doesn't turn easily. Leak, not shifting spool enough, spool not centering, etc. All the things that were covered previously.
