Re: 1963 Cub lowboy
Posted by Janicholson on June 12, 2011 at 19:11:39 from (67.72.98.45):
In Reply to: 1963 Cub lowboy posted by diesel cowboy on June 12, 2011 at 19:03:32:
The seal is common, and can be cross referenced if you have it out. (some of the production might use an Oring instead) Look up the part number at the caseih.com site. It is different than it was, buit still works.
Jim
