Re: Cub IS Charging?
Posted by Owen Aaland on June 12, 2011 at 20:27:39 from (216.47.33.99):
In Reply to: Cub IS Charging? posted by equeen on June 11, 2011 at 14:36:55:
You really need to check the voltage with the engine running. A fully charged battery, when put under a large load like cranking the engine, will have a lower voltage right after the load is taken off. Then it will slowly recover some or most of the lost voltage. That may be the effect that you are seeing. In order for the battery to be recharged it needs at least a half a volt above the full charge voltage. Anything less than about 6.8 volts in not going to recharge the battery.
