Re: super c rear wgts
Posted by farmallhal on June 13, 2011 at 17:58:15 from (184.6.78.82):
In Reply to: super c rear wgts posted by lilmac on June 13, 2011 at 17:33:47:
You are about right on the one piece rear wheel weights as I've seen them mentioned as 140 lbs. each. There are also front wheel weights available for the Super C which are 42 1/2 pounds each and also front frame weights are also available for the SC tractor model. Hope this helps, Hal.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
