Re: A press fit crank pulley...aint
Posted by Janicholson on June 13, 2011 at 19:11:48 from (67.72.98.45):
In Reply to: A press fit crank pulley...aint posted by truckinthumbtack on June 13, 2011 at 15:52:10:
If you make a setscrew for the new one it will be out of round. The difference is substantial. The real solution is to get the correct pulley with a set screw. I would have some measurements taken to assure me that the crank was standard (correct for year) size. If the old pulley was welded, there is no telling what has been done. Most 113Cid pulleys are a dramatic press fit, requiring a hydraulic press or great puller with splitter on the pulley to remove. And pressure to install. The setscrew pulleys would not be loose, they would be near zero clearance to light press. Jim
