Re: What am I missing? continued
Posted by Buzzman72 on June 13, 2011 at 19:34:25 from (74.129.193.163):
In Reply to: Re: What am I missing? continued posted by FC Andy on June 13, 2011 at 14:54:03:
Not even allowing for what the regulator is or sin't doing, three 25-watt bulbs should only be pulling 12.5 amps total...NOT 20 amps. So apparently there's an extra draw somewhere in the light circuit to begin with. If it was me, I'd be trying to track down what's drawing those extra amps first. WHY? Because once you get the current draw from the lighting circuit corrected, then there's a lot less of a deficit to be concerned with in the charging circuit.
But that's just me, and how I'd approach things. Other folks might go about it differently. But once the current draw from the lighting circuit is corrected, that's one less problem to deal with...because there apparently IS a problem there.
