Re: 1963 Cub lowboy
Posted by Janicholson on June 13, 2011 at 19:41:21 from (67.72.98.45):
In Reply to: Re: 1963 Cub lowboy posted by diesel cowboy on June 13, 2011 at 18:59:33:
Not too uncommon, the throwout bearing is graphite and has more friction than a ball bearing style. If it is quiet and holds the engine, leave it be until it needs a clutch, then replace it with a Ball style carrier and bearing. Jim
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
