Re: Mounting rear rim to hub, Something's not quite right...
Posted by DanR on June 14, 2011 at 05:04:11 from (67.236.1.105):
In Reply to: Mounting rear rim to hub, Something's not quite right... posted by Mr Farmall on June 12, 2011 at 16:09:23:
It's probably the weight of the tire and rim that is giving you grief. As you gently tighten the lugs rotate the tire back and forth as you tighten. All rims have some slop and this moves it to a different place. It will go away as the rim centers itself.
