Re: 656 Diesel switch to one wire alt.
Posted by Bob M on June 14, 2011 at 11:22:09 from (67.240.171.41):
In Reply to: 656 Diesel switch to one wire alt. posted by c-man on June 14, 2011 at 10:55:55:
Normal practice is to connect the alternator output wire to the battery side ("hot") terminal on the starter solenoid. However you can also connect it directly to the battery positive terminal if that's easier.
Unfortunately the Delco 1-wire alternator will not accommodate an idiot light. Suggest instead mounting a voltmeter with an on/off switch in the dash to monitor alternator operation. Wire the voltmeter directly between the battery + and a good ground.
