Re: A press fit crank pulley...aint
Posted by gene bender on June 14, 2011 at 17:06:06 from (207.177.56.53):
In Reply to: A press fit crank pulley...aint posted by truckinthumbtack on June 13, 2011 at 15:52:10:
Better have someone mike the crank. Adding a set screw if it doesent fit any thghter than that wont keep it on. Your crank must be worn from a loose fitting pulley. If you do add a set screw make sure its short enough to clear the casting and i would place it over the key if you can.
