504 manifold on an 350?
Posted by 1949H on June 14, 2011 at 18:05:39 from (69.43.65.74):
Hey everybody, just out of curiosity would a manifold from a farmall 504 line up correctly to a farmall 350 block? also would a farmall 350 carb mount correctly to a 504 manifold?
thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
