Posted by sflem849 on June 14, 2011 at 19:17:07 from (69.197.84.78):
In Bob M's diagram he calls for a warning light or a diode. What is the purpose of this?
On my neighbors VAC and my B there is a switch that is rigged into the 3 wire alternator system. What is the purpose of the switch? IIRC it is rigged into the Bat connection on the VAC alternator. Where should you run the switch? I would go check where it is tied in, but it is dark and there are skunks out there! :lol:
On my MD there is no switch, but there is a thing tied into the oil pressure gauge. This leads me to believe that it is there to excite the alternator. This also leads me to believe that the switch is possibly a manual alternator exciter.
Why don't I see a ballast resistor on the VAC or the B? I doubt I need one on the MD because it was originally 12 volts from the factory.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
[More Ads]
