It is a very tight press fit. A bearing splitter is needed behind the pulley or it will break. The puller must have serious capacity (3/4" threads on the push bar.) Several have been made and can be found in the archives. Heating the pulley with propane is OK, with Oxy torch risky. Heat will toast the seal, so cleaning up the shaft and hole before putting it together is a good idea. It needs to be a press fit, but not excessive. Be sure it goes in all the way to its limit. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
