Re: Farmall A Crank pulley won,t come off
Posted by P and R Pete on June 15, 2011 at 16:04:44 from (173.86.52.81):
In Reply to: Farmall A Crank pulley won,t come off posted by Joe schneider on June 15, 2011 at 13:30:08:
Joe, here's a picture of what I used, as Mr. Nicholson and CNKS described. The threads you are describing are internal, in the crankshaft, but have nothing to do with the pulley, except that you can use those threads to pull the pulley back on.
As CNKS describes, I had a big-*ss bearing separator, and tightened it good behind the pulley. You want it to press against the thickened
'shoulder' on the back of the pulley that is only maybe 3/4 of the width of the pulley itself. Don't pull on the perimeter of the pulley, or it will break.
In my picture, the upper and lower arrows point to the jaws of the puller overhanging the bearing separator. The question is then where to put the 'point' of the puller, since you don't want to bung up the internal threads. I screwed a bolt into those threads (I think they're 7/16's), and then drilled a 'divot' onto the center of the head of the bolt, as a 'seat' for the point of the puller, because otherwise it wanted to 'walk' around the head of the bolt.
third party image
I heated it with a propane torch for maybe 15 minutes (or it seemed like that long) until it was too hot to touch, and then cranked on the puller, even WAY harder than I thought was prudent, and as CNKS said, I heard a LOUD *bang* and thought I broke something, but it was just the pulley starting to slip. It had to *bang* one more time before it started to come off easier.
Don't forget to inspect the part where the middle arrow points, where the seal rubbed. I put on a speedi-sleeve. Don't want this worn area to muck up your new seal.
