Re: Farmall A Crank pulley won,t come off
Posted by El Toro on June 15, 2011 at 17:58:59 from (108.15.86.54):
In Reply to: Farmall A Crank pulley won,t come off posted by Joe schneider on June 15, 2011 at 13:30:08:
third party image
Here's what Bigdog made for his Cub. You could make one to fit your A or have a local metal shop make one and use 3/4 allthread with a hydraulic jack or ram. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
