Re: 986 T. A.
Posted by Janicholson on June 16, 2011 at 08:29:15 from (199.17.6.81):
In Reply to: Re: 986 T. A. posted by Info needed on June 16, 2011 at 07:31:45:
The issue is probably the one way clutch in the rear of the TA. If it slips, the TA is then driving through the rear TA locking clutch which is not designed to hold engine power, just prevent freewheeling.
My first step would be to over fill the Hydraulic system with five gallons. It will not hurt anything. If that fixes it, there is a suction leak in the MCV pump supply. If it does not, The issue is probably the one way clutch. Jim
