Re: 1948 Super A Starter Question
Posted by Janicholson on June 16, 2011 at 19:43:34 from (67.72.98.45):
In Reply to: Re: 1948 Super A Starter Question posted by JRSutton on June 16, 2011 at 19:16:31:
If it is grenaded, it likely took out or damaged the field as well. A good used is fine and may be less expensive if you feel OK putting bushings, brushes, and a new style drive in it.
Stuck switches, or contacts will allow them to over rev. Especially if on 12 volts or a booster.
They can stand it for a few seconds, but have been known to explode, even on 6volts. That series wound motor is not self limiting especially when it is not loaded. Jim
