Re: MTA overhaul kit
Posted by Janicholson on June 16, 2011 at 20:02:05 from (67.72.98.45):
In Reply to: Re: MTA overhaul kit posted by cazzhrdwd on June 16, 2011 at 19:42:07:
If it were mine, I would put larger bore, and domed pistons. (Part No: BIFH1164) $422.67 Would be for pistons and short block rebuild only
or Part No: EOK1164A-LCB $622.13) For comprehensive including head. Follow the directions and call if in doubt.
The bearings are ordered by the machine shop doing the crank, it will always be different. The above is My opinion, Jim
