Posted by Lmack on June 16, 2011 at 20:28:44 from (72.145.195.201):
In Reply to: paint removal posted by farmallboy15 on June 16, 2011 at 16:55:56:
If it is that hard to get off and it will look OK, why remove it? Just a thought. It will need to be roughed up with a brush, but I suspect that you have done that. I have painted over with a sand-able primer to smooth out edges. I have also used Muriatic Acid to clean small parts like plow shanks that you just can't clean with a brush or with a sandblaster. Using either Sodium-Hydroxide (oven cleaner) or acid a long soak in water following is absolutely necessary. I would only use these on small parts.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
