Re: Timing Super A
Posted by Scotty HOMEy on June 16, 2011 at 21:33:44 from (70.105.245.149):
In Reply to: Re: Timing Super A posted by Goodman on June 16, 2011 at 07:46:37:
If your flywheel cover is of the cast variety, the rib is more of a fin on the inside of the casting. If the cover is the stamped steel one, it is the vertical rib stamped into it.
Either one should line up with your timing mark at 6:00, but that cover does need to be installed. Dead bottom on the flywheel mark is TDC on #1 and #4.
