Re: Farmall 130 Distillate Tractor(with pics)
Posted by BMD on June 17, 2011 at 08:25:53 from (71.62.52.3):
In Reply to: Re: Farmall 130 Distillate Tractor(with pics) posted by rustyfarmall on June 17, 2011 at 06:24:22:
Thanks for the info. Apparently that was the last generation to have distillate as an option.My guess is that option was produced in very limited numbers.
I had thought distillate had been phased out of use in the USA long before the late 50's.
Would anyone happen to what or if there is a modern equivalent of distillate fuel today? Not planning to try it out but just curious what it is similar to?
Probable should leave it as is since it appears to be 100% original and runs good. Guess it gets to stay inside the nicer building next to Oliver 440 and 50 cub. Guess that still leaves the 140,364 and 664 to do the really hard work around the place.
thanks for the info
BMD
