Yes most of the latest update parts that become standard on a lot of 560 can be installed. Need differential and bearings, differential carriers with bearing race and o rings, shims and tapered shim., bull pinion gears and bearings, bull pinion retainers, bull gears, axle bearings, roller bearing for the pinion shaft. If you want the tractor to look original the 560 bull pinion shaft retainers need the od turned down to 400 od size using the 400 brakes. 560 brakes and brake parts can be installed. If 560 is used some 560 parts like t/a operating handle bracket and linkage is needed along with a little grinding for bolting the bracket to axle housing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
