Posted by pete 23 on June 17, 2011 at 19:18:49 from (74.32.230.16):
In Reply to: super h sleeves posted by rick deere on June 17, 2011 at 10:41:03:
Did you try to see if the flange of the sleeve fit into the block inverted before you pressed the sleeves in. If it protrudes that much it is eiether over sized diameter flange or way too thick a flange. Some suppliers are having a problem with getting the correct thickness but not that much. Note that the head gasket crosses over the flange so you want very little protrusion or you will have a leaking head gasket.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
