Re: Farmall Super A hi-comp pistons.
Posted by Red Dave on June 19, 2011 at 11:10:09 from (98.235.13.108):
In Reply to: Farmall Super A hi-comp pistons. posted by Aussie John on June 19, 2011 at 03:10:32:
High compression, oversized pistons is pretty much a standard upgrade when overhauling these engines.
Do yourself a favor and don't order the sleeve & piston kit until you have pulled the engine apart and measured the inside diameter of the bore at the bottom of the sleeve, where the O-Ring seal is. That diameter will determine what the Outside Diameter is of the sleeves you need. There was a change in that during the Super A run and you want to be sure to get the right parts.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
