Re: Fuel sediment bowl replacement
Posted by rustyfarmall on June 19, 2011 at 12:20:43 from (216.248.71.224):
In Reply to: Fuel sediment bowl replacement posted by LRRifleman on June 19, 2011 at 07:46:19:
I think you might want to remove the fuel tank and give it a thorough cleaning. You've got, or did have water in the tank. That water is causing the corrosion. Gasoline does not corrode. Diesel fuel does not corrode. Ethanol does not corrode. It is the water that is causing your problems.
I've not ever had any problems with aftermarket sediment bowl assemblies corroding like you describe.
