Re: Farmall seals
Posted by MV_51 on June 19, 2011 at 14:23:30 from (86.89.136.133):
In Reply to: Re: Farmall seals posted by D Slater on June 15, 2011 at 18:36:20:
I always see the big money amounts for seals wich are used in our Farmall's in USA.I always order them with a company and the Tokseals and NAK seals cost me a fraction Euro's even when I recalculate to Dollars.
E.g. the seals for the rearaxles 95mm-70mm-10mm/12mm cost a fraction and are good brands (not from China)for around US4,-(?)or US9,- for the 13mm.Is that because of the fact there is an Case IH plastic wrapped around the seals....
Just the same as with the oil filters.They are all from Fleetguard factory but way cheaper as purchased from my IH dealer and exactly the same (like recalculated the LF618 H $4,18 $5,62 LF584 M
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
