Re: F-20 piston rings?
Posted by Bill Lisbon on June 19, 2011 at 15:11:33 from (69.89.163.184):
In Reply to: F-20 piston rings? posted by oldiron29 on June 19, 2011 at 14:55:53:
I have seen IH diesels with 2 oil rings, I think it would run fine with 2 oil and 2 compression rings. No trouble use high altitude pistons, unless you are running on kerosene.
