Re: skip
Posted by chris truax on June 19, 2011 at 19:47:27 from (76.120.9.218):
In Reply to: skip posted by logan123 on June 19, 2011 at 19:30:52:
I had an H that misfired intermittently when cold. It was a valve that was worn out and didnt always seat well. pull your muffler off so you can see in the exhaust manifold and look for fire from either one end or the other while its running.
Also, with your carb- if its the same style at the older f-12s, the float is something that gets ignored on some carb rebuilds and it will come back to haunt yOU. Even if it tests ok-replace it
