Re: 1456 worth
Posted by oldtanker on June 19, 2011 at 19:52:17 from (66.228.255.223):
In Reply to: 1456 worth posted by Shawn W on June 19, 2011 at 18:54:21:
Sounds like it dumped the IPTO shaft. That entails splitting the tractor. So yer looking at about 700 or so in parts if the throw out bearing shaft/flange is OK. A bit more for that. That's if you do the work. I just did a 1206 and 986 this winter. 1206 was clutch, pressure plate, throw out bearing, IPTO shaft and seals for the tranny/IPTO and rear engine seal. I spent about 800 for everything. The 986 belongs to a freind. That was all of the above plus the throw out bearing shaft/flange. That ran close to 1K including new IPTO shaft bearings.
Rick
