Re: Need Help Identifying IH Lustran Seed Plates
Posted by LA in WI on June 19, 2011 at 21:31:03 from (50.50.95.40):
In Reply to: Re: Need Help Identifying IH Lustran Seed Plates posted by RTR on June 19, 2011 at 19:50:42:
RTR, those numbers are for corn plates. All the plates are 24 cell (that's what the "24" after the dash means. If you use these plates your planter has to have it's sprocket settings geared for 24 cells. Many old planters used 16 cell plates so take note. Refer to your owner's manual for the correct sprocket settings.
I do not think you have a real "good buy" at those prices, as plastic plates are plentiful. But if they are new then it's your money.
You do NOT need all those plate numbers. I am listing the plates in descending order of cell sizes. (There is no rhymm or reason to the numbers as they are not in descending order).
C13 large round seed
C54 (very seldom needed)
C1X medium round
C15 (very seldom needed)
C2X small round
C25 (very seldom needed)
C3 very small round
C8 large flat seeds
C11 med large flat
C7 med flat
C65 (seldom needed)
C6 small med flat
C10 (seldom needed)
C9 small flat
C19 very small flat
Do you have any plates that came with that planter? If so, are they 16 or 24 cell? (Count the cells around the perimeter).
LA in WI
