Re: 574 power steering
Posted by bsekf on June 20, 2011 at 07:07:39 from (69.207.59.103):
In Reply to: Re: 574 power steering posted by Jimb2 on June 11, 2011 at 19:28:34:
Jimb2,
I have been reading the archives on PS and related Hyd. problems on a 574. Before I take the splitter valve out I want to make sure that is where my problem probably lies.
When the PS fails, the steering wheel turns freely but nothing happens to the front wheels, it has only happened when going down a steep hill. The first time the fluid was low but the second time fluid level was over full. All other hyd. work pretty much as they should, even draft control. If lifting an implement with the 3PH, the PS works hard until implement is lifted. Steering wheel does not free wheel under that circumstance. My hyd. system has been drained and a new filter and fluid installed a year ago when I had the PTO clutch rebuilt.
help
Bill
