Re: Farmall C (Restoration Questions)(Memory of Grandfather)
Posted by gregk on June 20, 2011 at 15:59:58 from (99.196.64.57):
In Reply to: Farmall C (Restoration Questions)(Memory of Grandfather) posted by LJS30 on June 20, 2011 at 12:43:32:
Well not to argue a fine point here, but if you are married DON'T write down what everything costs! Just kidding.New tires are expensive but worth it, and if you are putting on new tires just go ahead with new tubes for them. As far as the engine, if it runs fine, has good oil pressure, and doesn't smoke I would leave it alone as it will never probably see much use again. New brakes are a good idea , and not expensive. Any seal or gasket that leaks or is taken out even if it doesn't leak should be replaced. Also the front and rear main seals on the motor should be replaced. All in all it's your tractor, do with it what you want and enjoy. Keep us posted with how it goes!
