Re: 464 International fuel leak
Posted by JimB2 on June 20, 2011 at 17:11:38 from (99.240.236.11):
In Reply to: 464 International fuel leak posted by Jason the Red on June 20, 2011 at 13:51:20:
Hi, look at attach parts diagram from caseih.com of 464 Fuel Tank.
Could be that flange on pipe fitting is cracked. If that is the problem then you will have to replace a section of fuel line.
JimB third party image
