Re: 574 power steering
Posted by Jimb2 on June 20, 2011 at 17:28:03 from (99.240.236.11):
In Reply to: 574 power steering posted by bsekf on June 11, 2011 at 14:14:27:
Hi Bill, the steering wheel should never free wheel, if the hydraulic pump stops supplying pressure the the steering wheel should just be hard to turn as now the hand pump in the steering mechanism is being used.
Most likely caused by an air lock. Be sure transmission is over filled by 5 gal.
JimB
