I have one that looks similar, but runs like a top. Probably the only reason I still have it, is that it belonged to my father, and was the first thing I ever drove sitting on his lap when I was around 5 or so in the early 60"s. I use it for cutting around 60 acres of hay each year with his old sickle mower, and maybe pulling a load or two of firewood in the winter, but that is about it. It seems I redo some portion of it each year, and completely redid the touch control last year. Sooner or later I will tear it completely down and de-rust and paint and put back together, however it will likely be a $150 paint job, as I plan on using it, and not being afraid of scratching it a little if a limb drags across the hood or grille. Easy to touch up. My engine smokes a bit at idle or if it sits a bit idling, but with no more use than it gets it will likely last longer than I do. As someone said, don"t rush it, and think carefully on how you want to use it, and redo it accordingly. I liked the idea of keeping mine running and redoing a little at a time until it is ready for paint. I decided I have little use for a show piece, and put it in the fields as much as I can.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
