Re: Re: M idles to fast
Posted by Jim on August 07, 2000 at 07:31:13 from (12.76.65.246):
In Reply to: Re: M idles to fast posted by The Red on August 07, 2000 at 04:26:31:
That tube is a vent line, doesn't supply oil for gov. if adjusting screw is not touching case,( in idle postion,) this adjusment will not make any difference. If tang that engages the carb. on the cross shaft is worn it can cause this problem and the adjustment from the vertial gov. shaft to the cross shaft to carb. also will cause it.
Post A Followup
: Re: Re: Re: M idles to fast
