Re: 1930 Farmall Regular Manifold Stud Bolts
Posted by Jerry Claborn on June 21, 2011 at 14:47:10 from (75.137.240.212):
In Reply to: Re: 1930 Farmall Regular Manifold Stud Bolts posted by JRSutton on June 21, 2011 at 09:03:18:
Thanks for the suggestions. Since the head threads are rusty, should I use some type of cleaner before installing the new studs?
