Re: Farmall 130 block for Super A: Pics included
Posted by El Toro on June 21, 2011 at 17:04:02 from (108.15.86.54):
In Reply to: Re: Farmall 130 block for Super A: Pics included posted by GRAPE-DRANK on June 21, 2011 at 08:07:08:
Once they polish it if that's all it needs and doesn't require to be ground undersize have the shop to furnish the correct insert bearings. If it needs to ground have them furnish the correct bearings and use the old bearing caps if the bearing caps haven't had a spun bearing.
If the 130 uses the same sleeves as the Super C
they should measure 7-1/32" in length and measure 3.4375" at the seal. Hal
