Re: Outer rear axle bearing on 504U
Posted by RPM1941 on June 21, 2011 at 18:48:00 from (173.25.71.175):
In Reply to: Outer rear axle bearing on 504U posted by LKY BOB on June 21, 2011 at 09:39:39:
The hub is held on with the cap screw in end of axle splines, assuming not a tractor with slideable axle option, hub comes off, then the cap & seal. If brng is failing get it out with slide hammer.
