Re: 300u hydraulics all messed up
Posted by Roger46 on June 21, 2011 at 19:06:37 from (75.221.225.230):
In Reply to: 300u hydraulics all messed up posted by antique hay co on June 21, 2011 at 16:16:36:
Did you check the clearances in the pump when you had it apart? Sounds like the gears may be worn and after putting it back together it is unable to prime itself. Roger
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
